Tools in NX 7.5 64 bit
Have you ever faced the problem with tool picking in NX-64 bit installed in Win 7?
When I choose, e.g. drilling operation and inside the operation window I pick the tool, choose new drill and windows switches to tool parameter window, what I see is Milling Tool 5-parameters, not drilling tool. The same more likely on the others, e.g countersunk tool.
Somebody knows the problem?
RE: Tools in NX 7.5 64 bit
This is a known problem, already fixed in 7.5.2.
Create the tool before you edit the operation to avoid it.
Mark Rief
Product Manager
Siemens PLM
Thank you, Mark. Do you know, when it will be realeased?
I known that it is planned for next week
Didier
Thanks, ExpertNX
