Plug Weld Diameter
Plug Weld Diameter
Plug Weld Diameter
Hello all,
1st post in this forum.
I was wondering if there is a standard or similar that determines the hole diamter for doing plug welds.  For example, if I need to plug weld two 12awg plates together what dimater should be drilled in the top plate?
Thanks for any input.
BB
