The Bushing has the bad C1 test result, but the good hot collar result
C1 (%PF): H1, H2, H3 => 1.49, 1.13, 0.74.
Hotcollar: H1, H2, H3 => 0.024, 0.03, 0.034.
Which test result you would use to judge the integrity of the bushings?
THanks
RE: The Bushing has the bad C1 test result, but the good hot collar result
Both, but I'd weight the C1 more heavily.  The hot-collar is sensitive to environmental factors, cleanliness, and technique.
What brand, type, and voltage?
1.49% is getting up there...
