Identifying co-ordinates with po2txt lisp
Can anybody help me, i have autocad 2010. I have been using a po2txt lisp app
to harvest survey co-ordinates from the autocad drawing and recording them on a text file.
Instead of been able to click on a mulitple points and recording them all in on go.
i suddenly find i can only record one set of co-ordinates at a time.
RE: Identifying co-ordinates with po2txt lisp
Can you select multiple objects using AutoCAD commands?  If not, maybe your PICKADD setting got changed.
