How do Sectionalizers work OR what do they do.
If you could, give an example setup of how they were used.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: How do Sectionalizers work OR what do they do.
As an example, suppose you have a permanent fault on an overhead line. If a recloser is programmed for 4 interrupting operations, the sectionalizer is usually set for 1 less operation. After the third operation of the recloser, the sectionalizer drops open. This permits the recloser to close and just isolates the section of the circuit beyond the sectionalizer.
Ohh,so sectionalizers are downstream to the reclosers.
Also, how do they close the sectionalizers? manually ?
Thanks very much!!
Do you use sectionalizers at all right now?
