GM teamcenter issue
GM teamcenter issue
GM teamcenter issue
Hello, on certain machines, in NX5, 64 bit, connected to GM teamcenter, users here sometimes get, "Unhandled exception processing the current input part.  Failed with the message, memory access violation."
Memory access violation is the common phrase across all errors.   Siemens knows nothing about it.   Can anyone think of anything?
Thanks, Dean
RE: GM teamcenter issue
It might help to be as descriptive as possible.  I assume that the users aren't just sitting at the computer and error messages pop up out of the blue.  What are the users doing to initiate the error message?  Just opening part files?  Performing a modeling task?  A drafting task?  The more info you can provide, the better the help you may receive.
Have you tried to contact GM's Supplier Helpdesk about this issue?
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
Do you have thge latest maintenance release of NX5?
Ben Loosli
Hi, the easiest fix so far for this is to re-image the machine.   We serve NX so we try to stay even with our customer.   I appreciate everyone's ideas.
