Stress analysis: Zero, small negative element
Dear All:
I tried to run a sequential thermal and stress analysis by element activation technique. I have no issues running my thermal model but have trouble in mechanical model. When I run my mechanical model, the first element-set that gets activated has no convergence problem but when I activate the second element set it has the following warnings and the simulation aborts. I need some input, please help.
Warnings
STEP    3     INCREMENT     1     STEP TIME    0.00
                        S T E P       3     S T A T I C   A N A L Y S I S
     AUTOMATIC TIME CONTROL WITH -
          A SUGGESTED INITIAL TIME INCREMENT OF                5.000E-07
          AND A TOTAL TIME PERIOD OF                            3.00
          THE MINIMUM TIME INCREMENT ALLOWED IS                1.000E-20
          THE MAXIMUM TIME INCREMENT ALLOWED IS                 3.00
     LINEAR EQUATION SOLVER TYPE         DIRECT SPARSE
 CONVERGENCE TOLERANCE PARAMETERS FOR FORCE
     CRITERION FOR RESIDUAL FORCE     FOR A NONLINEAR PROBLEM          5.000E-03
     CRITERION FOR DISP.    CORRECTION IN A NONLINEAR PROBLEM          1.000E-02
     INIT. VALUE OF TIME AVG. FORCE     IS TIME AVG. FORCE     IN PREVIOUS STEP
     AVERAGE FORCE     IS TIME AVERAGE FORCE
     ALTERNATE CRIT. FOR RESIDUAL FORCE     FOR A NONLINEAR PROBLEM    2.000E-02
     CRITERION FOR ZERO FORCE     RELATIVE TO TIME AVRG. FORCE         1.000E-05
     CRITERION FOR RESIDUAL FORCE     WHEN THERE IS ZERO FLUX          1.000E-05
     CRITERION FOR DISP.    CORRECTION WHEN THERE IS ZERO FLUX         1.000E-03
     CRITERION FOR RESIDUAL FORCE     FOR A LINEAR INCREMENT           1.000E-08
     FIELD CONVERSION RATIO                                             1.00
     CRITERION FOR ZERO FORCE     REL. TO TIME AVRG. MAX. FORCE        1.000E-05
     CRITERION FOR ZERO DISP.    RELATIVE TO CHARACTERISTIC LENGTH     1.000E-08
     VOLUMETRIC STRAIN COMPATIBILITY TOLERANCE FOR HYBRID SOLIDS       1.000E-05
     AXIAL STRAIN COMPATIBILITY TOLERANCE FOR HYBRID BEAMS             1.000E-05
     TRANS. SHEAR STRAIN COMPATIBILITY TOLERANCE FOR HYBRID BEAMS      1.000E-05
     SOFT CONTACT CONSTRAINT COMPATIBILITY TOLERANCE FOR P>P0          5.000E-03
     SOFT CONTACT CONSTRAINT COMPATIBILITY TOLERANCE FOR P=0.0         0.100
     CONTACT FORCE ERROR TOLERANCE FOR CONVERT SDI=YES                 1.00
     DISPLACEMENT COMPATIBILITY TOLERANCE FOR DCOUP ELEMENTS           1.000E-05
     ROTATION COMPATIBILITY TOLERANCE FOR DCOUP ELEMENTS               1.000E-05
 EQUILIBRIUM WILL BE CHECKED FOR SEVERE DISCONTINUITY ITERATIONS
 TIME INCREMENTATION CONTROL PARAMETERS:
     FIRST EQUILIBRIUM ITERATION FOR CONSECUTIVE DIVERGENCE CHECK              4
     EQUILIBRIUM ITERATION AT WHICH LOG. CONVERGENCE RATE CHECK BEGINS         8
     EQUILIBRIUM ITERATION AFTER WHICH ALTERNATE RESIDUAL IS USED              9
     MAXIMUM EQUILIBRIUM ITERATIONS ALLOWED                                   16
     EQUILIBRIUM ITERATION COUNT FOR CUT-BACK IN NEXT INCREMENT               10
     MAXIMUM EQUILIB. ITERS IN TWO INCREMENTS FOR TIME INCREMENT INCREASE      4
     MAXIMUM ITERATIONS FOR SEVERE DISCONTINUITIES                            50
     MAXIMUM CUT-BACKS ALLOWED IN AN INCREMENT                                 5
     MAXIMUM DISCON. ITERS IN TWO INCREMENTS FOR TIME INCREMENT INCREASE      50
     MAXIMUM CONTACT AUGMENTATIONS FOR *SURFACE BEHAVIOR,AUGMENTED LAGRANGE    6
     CUT-BACK FACTOR AFTER DIVERGENCE                                 0.2500
     CUT-BACK FACTOR FOR TOO SLOW CONVERGENCE                         0.5000
     CUT-BACK FACTOR AFTER TOO MANY EQUILIBRIUM ITERATIONS            0.7500
     CUT-BACK FACTOR AFTER TOO MANY SEVERE DISCONTINUITY ITERATIONS   0.2500
     CUT-BACK FACTOR AFTER PROBLEMS IN ELEMENT ASSEMBLY               0.2500
     INCREASE FACTOR AFTER TWO INCREMENTS THAT CONVERGE QUICKLY        1.500
     MAX. TIME INCREMENT INCREASE FACTOR ALLOWED                       1.500
     MAX. TIME INCREMENT INCREASE FACTOR ALLOWED (DYNAMICS)            1.250
     MAX. TIME INCREMENT INCREASE FACTOR ALLOWED (DIFFUSION)           2.000
     MINIMUM TIME INCREMENT RATIO FOR EXTRAPOLATION TO OCCUR          0.1000
     MAX. RATIO OF TIME INCREMENT TO STABILITY LIMIT                   1.000
     FRACTION OF STABILITY LIMIT FOR NEW TIME INCREMENT               0.9500
     TIME INCREMENT INCREASE FACTOR BEFORE A TIME POINT                1.000
     AUTOMATIC TOLERANCES FOR OVERCLOSURE AND SEPARATION
     PRESSURE ARE SUPPRESSED
     GLOBAL STABILIZATION CONTROL IS NOT USED
     FRICTION IS INCLUDED IN INCREMENT THAT THE CONTACT POINT CLOSES
          PRINT OF INCREMENT NUMBER, TIME, ETC., EVERY    1  INCREMENTS
     THE MAXIMUM NUMBER OF INCREMENTS IN THIS STEP IS                   10000
          LARGE DISPLACEMENT THEORY WILL BE USED
     LINEAR EXTRAPOLATION WILL BE USED
     CHARACTERISTIC ELEMENT LENGTH     5.908E-04
     DETAILS REGARDING ACTUAL SOLUTION WAVEFRONT REQUESTED
     DETAILED OUTPUT OF DIAGNOSTICS TO DATABASE REQUESTED
     PRINT OF INCREMENT NUMBER, TIME, ETC., TO THE MESSAGE FILE EVERY     1  INCREMENTS
 ***ERROR: THE VOLUME OF ELEMENT 76221 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76221 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             THE ISOPARAMETRIC LINES IS LESS THAN 45 DEGREES OR GREATER THAN
             135 DEGREES. THE MIN/MAX ANGLE IS 26.670 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76222 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76222 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 42.165 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76223 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76224 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76225 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76225 INSTANCE PART-1-1 HAS AN ASPECT RATIO EXCEEDING 100
             TO 1.
 ***WARNING: ELEMENT 76225 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 41.572 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76246 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76246 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 26.627 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76247 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76247 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 42.539 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76248 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76249 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76250 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76250 INSTANCE PART-1-1 HAS AN ASPECT RATIO EXCEEDING 100
             TO 1.
 ***WARNING: ELEMENT 76250 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 36.959 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76271 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76271 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 26.682 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76272 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76272 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 42.752 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76273 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76274 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76275 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76275 INSTANCE PART-1-1 HAS AN ASPECT RATIO EXCEEDING 100
             TO 1.
 ***WARNING: ELEMENT 76275 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 32.503 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76296 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76296 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 26.741 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76297 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76297 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 42.609 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76298 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76299 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76300 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76300 INSTANCE PART-1-1 HAS AN ASPECT RATIO EXCEEDING 100
             TO 1.
 ***WARNING: ELEMENT 76300 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 37.051 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76321 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76321 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 26.892 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76322 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76322 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 42.312 DEGREES.
 ***ERROR: THE VOLUME OF ELEMENT 76323 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76324 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***ERROR: THE VOLUME OF ELEMENT 76325 INSTANCE PART-1-1 IS VERY SMALL OR
           NEGATIVE.
 ***WARNING: ELEMENT 76325 INSTANCE PART-1-1 HAS AN ASPECT RATIO EXCEEDING 100
             TO 1.
 ***WARNING: ELEMENT 76325 INSTANCE PART-1-1 IS DISTORTED. THE ANGLE BETWEEN
             135 DEGREES. THE MIN/MAX ANGLE IS 41.445 DEGREES.
   ELEMENT PART-1-1.76221 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76222 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76223 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76224 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76225 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76246 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76247 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76248 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76249 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76250 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76271 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76272 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76273 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76274 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76275 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76296 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76297 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76298 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76299 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76300 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76321 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76322 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76323 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76324 IS DISTORTING EXCESSIVELY.
   ELEMENT PART-1-1.76325 IS DISTORTING EXCESSIVELY.
 ***WARNING: 15 elements are distorted. Either the isoparametric angles are out
             of the suggested limits or the triangular or tetrahedral quality
             measure is bad. The elements have been identified in element set
             WarnElemDistorted.
 ***WARNING: The aspect ratio for 5 elements exceeds 100 to 1. The elements
             have been identified in element set WarnElemAspectRatio.
 ***ERROR: The volume of 25 elements is zero, small, or negative. Check
