Sizing of a catch basin for roof drains and/or water bottoms
Is there a method to calcuate the size of a catch basin or sump for collecting roof drains or water bottoms off a storage tank?  Been searching through API650 and I cannot find a general equation which relates the tank size to the size of the catch basin.  Any help would be appreciated
RE: Sizing of a catch basin for roof drains and/or water bottoms
I've never heard of a code required size or a special formula.  650 certainly doesn't have one.  I think you just use common sense considering: 1) the expected flow rate, 2) the frequency of use, and 3) the amount of water expected  (in the case of a water bottom collection.)
The expected flow rate is a function of the max height, the diameter of the sump / drain piping, and in the case of floating roof drains, the max rainfall rate.
