Rerating of SA-106B pipe for low temperature,
Could a piece of SA-106B pipe which has been in service for 10 years be rerated for another service with lower pressure and low temperature (-40°C) withought impact test using Fig 323.2.2B of B31.3 or API 579 should be used for this purpose?
RE: Rerating of SA-106B pipe for low temperature,
Yes, it is possible provided the current condition of the pipe is evaluated, and a FFS evaluation for the new design conditions is performed using ASME/API FFS-1.
API 579 FFS is recommended. You will no doubt be required to perform some impact testing from samples removed from the pipe.
Doesn't B31.3 apply to only new equipment/piping though?
Correct;  ASME B31.3 is a design/construction Code only.  However, API-570 for in-service pipe refers back to it a lot.  The *Official* Code(s) would be listed as API-570, ASME/API-FFS-1, API 579, etc.,  but you will predominately be working out of B31.3.
