surge protection
surge protection
I review the design of sewage transmission line from pumping station to sewage treatment plant, found air valve without any surge tank, material pe 100 DN315mm PN10, pipe length 3345 m, IS THAT RIGHT OR NOT
RE: surge protection
If you have undertaken a surge analysis you will know if a gas accumulator is the correct solution.
