Fire flow test using a 4 inch port with a reducin fitting to 2.5 inch
Good Day to all,
This is my first posting and I'm feeling rather invigorated for the outcome this posting may generate.
Question, a hydrant has been flow using the pumper port (4 inches). This pumper port has been fitted with a 2.5 inches reduced down fitting (from 4 inch to 2.5inch). My question to the forum is. Should I be using the flow table for a 2.5 inch port or the 4 inches port or is there a mathematical equation to calculate the equivalent flow of a 4 inches port.
I am confused, please help?
Thank you
Thank you
RE: Fire flow test using a 4 inch port with a reducin fitting to 2.5 inch
It depends on where your flow sensor is located...
Can you provide us a aketch with approximate dimensions? It's hard to visualize what you're asking.
Good on ya,
Goober Dave
