machining tolerances for plastics
I am looking for machining tolerances to be used when
specifying tolerances on machined plastic components
( teflon,delrin and nylon,poluurethane)
It would be appreciated if anyone could point me in the right direction
Best regards from south africa
fred evans
RE: machining tolerances for plastics
Here two guides on that should get you started with machining plastics. I have always look at setups for Aluminum as a starting point for machining plastics. You need to get specific machining instructions for what ever material you are working with.
http:
http://w
Obviously though manufacturing capability does have to be taken into account.
unclesyds links are nice, I'd also look at talking to your likely vendors/machine shops and talking to the manufacturers of the specific plastics.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
The site is a little convoluted so look around
ht
