Pipe sign transition
I have a 50 foot tall sign in which I am using a 34" od pipe at the base and then making a transition to a 24" od pipe and then to a 14" od pipe. Not too concerned about a smooth looking transition. But want to know what the best way to connect the two different diameter pipes together. Thanks.
RE: Pipe sign transition
If the pipe is designed to max at the splice, then you need a CJP weld.
Dik
iv
Dik
There is another rib-flange that welds to the top of larger pipe.
This pretty much the way step-tapered flag poles are constructed. Not pretty but adequate.
