Automating Tolerances
I have a diameter 'D'.
The tolerance is always +0.000 -0.01D
Is it possible to define tolerances in a way that will calculate 0.01D?
RE: Automating Tolerances
No there is no direct way to do it. Not sure if it can be achieved via a macro.
Deepak Gupta
SW 2009 SP4.1 & 2007 SP5.0
MathCAD 14.0
Boxer's Blog
It can be done using a a macro, if you need to change the tolerence of all dimensions in a current drawing.
Use 'DimensionTolerance' class. Let me know if you want to make a macro. I'll give it a try.
Suloke,
Thanks for the tip. I know nothing about macro's so any help would be appreciated.
