connector
connector
connector
Does any body know what i can use to tap multiple feeds into one. A replacing multiple transformers to one tranformer, i need to tap the cables running from the new transformers to the cable of the existing building..
RE: connector
Voltage?  Amperage?  Location in the world.?  Our mind readers have moved on to other pursuits.
David Castor
www.cvoes.com
RE: connector
dpc is right, with due respect kindly specify what is your transformer capacity.. to lessen comments that might suffice your question.
"..the more, the merrier" Genghis Khan
