High temperature transparent polymer
Hi. I need a rigid material that can be used as a transparent window (2-3mm thick) in an induction heating application. Both the induction coil and the pyrometer (spectral wavelength = 2um) will be located at the opposite side to the material being heated. The temperature will reach approx 420C for short intervals (5-10seconds) and then allowed to cool naturally.
Any suggestions on a polymer material that might be suitable?
Many thanks.
Many thanks.
RE: High temperature transparent polymer
H
www.tynevalleyplastics.co.uk
If you need an alternate material look at the products offered by Axim.
htt
I am not sure of the short term thermal stability of transparent thermosets like Ally polymers (CR39)
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
http://www.quartz.com/quartz.html
http://ww
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
