The rule P=F/A Goes fail on Fluid in centrifugal pump why?
hii mech engineers
today i want to ask about pressure in centrifugal pump. as we knw the equation of pressure is P=F/A where
f=force
A=area
P=pressure its clear?
k now if we tale fluid passing through centrifugal pump then we knw fluid is incompressible so when fluid enters from inlet and enters in conversoin area section in casing of pump where fluid is in compressible so it trys to rush quickly from that area meas it increases velocity of fluid not a pressure. now in casing where diversion section the fluid pasees then its pressure increases, u noticed here as area increse the pressure of fluid increases..... why it happend i not got where as per pressure equartion i said as area decrese the pressure increses, but in this case in not happening why???
f=force
A=area
RE: The rule P=F/A Goes fail on Fluid in centrifugal pump why?
Force increases at a greater rate than the area increases. Therefore, pressure increases.
Ted
I have read the question over and over again and still I do not know what is being asked..?
Can anyone translate..?
Cheers
Adrian
Fe
