Problem with V11 (drafting / assembler)
I'm having major problems with some assembly drawings that I have produced.  The drawings were originally done in V8 and were fine.  Since then I now use V11.  I've updated the assembly files, but when I update the assembly drawing the whole thing just becomes invisible.  Why?
The original model was imported from IGES and had some problems, but it worked fine in V8.
The next thing I tried was to produce a draft drawing of the component in question, the same thing happens.
Can anyone help?
Many thanks
Mark
RE: Problem with V11 (drafting / assembler)
Have you gone in and updated all the parts and assemblies to v11?  We had some problems with v10 and some v8 parts similar to this.  Ended up having to go in and regenerate all the parts (clicl on ist element and recompute).  Then was ok.
