Outdoor Air Calculation
I have a question with concerns to Outdoor Air calculation. I have a Dictation Room within a hospital that is being reconfigured by the architects. This room has no exterior walls and is in the basement. The Volume of the room is about 3100 cubic feet and the Floor Area is about 400 square feet. I calculated the Heat Losses as follows:
Qlights = 3.41* (27*26W) *1*1*1 = 2400 BH
Qdesktop-lights = 3.41 * (5*50W)*1*1*1 = 900 BH
Qpeople = 5*250*1 = 1250 BH
Qequipment = 3.41 * (5*200W) *1*1*1 = 3500 BH
Qtotal = 8050 BH
CFM = 8050 / (1.085*(75-55)) = 371 CFM
The OA as per ASHRAE is recommended as 20CFM per person. Since there will be 5 people in the room, 100 CFM will be the amount the OA.
My question is the 100 CFM of OA added to the 371 CFM due to Heat Losses to make a total of 471 CFM of supply air or is 100 CFM part of the 371 CFM, that is, 371 CFM will be delivered to the space.
I would greatly appreciate it if someone could help me on this.
Qtotal = 8050 BH
RE: Outdoor Air Calculation
You also need to account for the cooling load of the 100 cfm of outdoor air which will vary depending on the conditioning or not of this air prior to it being supplied to the space.
You are correct. The OA will be mixed-in with the room return air (271 CFM 75'F / 50%RH of Room air mixed with 100 CFM of 90'F DB / 75'F WB of OA) where it will then be treated by a fan-coil unit (which is located in the ceiling space of the room) and then redistributed to the room. I calculated:
Q = 4.5 * 371 CFM * (31.4 - 22.6) = 14692 BH = 1.2 Tons of Total Cooling
Again, thank you.
and there is a coil load wich is used for equiment selection.
OA is a part of the coil load not the space load.
it doesn't effect on the cfm required for a particular space.
if you need a 2000 cfm for a space, you still need this 2000 cfm either you need 100 cfm or 200 cfm or.. of OA.
- your equation:
[air flow] is in cfm
[delta T] is in C degree
[Q] I guess is in BTU
what is 4.5 factor?.
and don't forget the latent load too
