Brake caliper piston seal design
Some time ago, there was a discussion of Brake Caliper sealing in thread108-98668: Brake Caliper sealing . This thread is now closed, but I would like to re-visit the topic. There was mention of o-rings that are trapezoidal in cross section. When pressure is applied, the o-ring distorts, and when pressure is released, the o-ring returns to its original shape, helping to retract the piston. This is in a design where the seal is in a groove in the cylinder wall.
I would be interested in seeing more detail on such designs. I spent some time searching on the web, but got nowhere.
RE: Brake caliper piston seal design
Mike Halloran
Pembroke Pines, FL, USA
It really is a very simple device. The only complexity is the relationship between the flexibility of the rubber ring and the friction on the piston and the force required to retract the piston. Oh and keeping it the same on both wheels is another important point.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Early disc brake seals and retraction mechanisms were very complex. Most of them worked when new, but didn't age well.
Simplicity won out, but _everything_ to do with that seal is now critical; surface finishes, dimensions, hardness, changes in hardness with age, fluid compatibility, all that stuff.
Mike Halloran
