How to re-order the parameter file in Inventor 2011
My bug is that it would seem that Inventor only allows for any new parameter values to be added to the bottom of the list and not inserted in a meaningful place to create a logically structured file.
I am able to modify the exported XML file produced by the parameter facility but if I re-import the duly modified XML file, Inventor simply adds any missing parameter values to the bottom of its list i.e. out of logical sequence.
Is there a way to re-order the file within Inventor 2011 or replace the existing file for an externally re-structured file?
Any help would be greatly appreciated.
Thank you,
cjj
Thank you,
cjj
