Boolean operations in Assembly
I have two parts in my assembly and one overlaps the other. I would like to make the overlap of part 1 remove the covered material in part 2 in solidworks 2010 assembly. Can anyone help?
Thanks.
RE: Boolean operations in Assembly
I think the simplest method would be to use a Cavity feature.  Look in SW help under Mold Features.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
You can also insert part 1 into part 2 and use combine bodies function to subtract part 1 from part 2.
Eric
