shell elemnt sap 2000 for 2d drawing
Hi
my question is that i have composite concrete and steel structure and i draw it 2d autocade but i dont know what to do to get shell elemnt in sap 2000 for that structure
top part is concrete and bottom part is steel,can you please give me a tip about the procedure
thank you
thank you
RE: shell elemnt sap 2000 for 2d drawing
Please also note that the following correlation between SAP2000 objects and DXF entities is applicable for importing a DXF file in SAP2000
Frames -- Lines
Shells -- 3Dfaces
Solids -- Meshed Polygon or Solid
