Automatic Load Solver.xla
Dear All,
I realised that not all Excel comes with Solver.xla "checked" as default (in Visual Basic Module). As a result, some of the macro I wrote which uses solver will not work in those computers unless the user manually select the solver check box.
Hence, I am wondering if anyone could teach me how to write a script which load Solver.xla automatically as part of a macro.
Many thanks!
EK
RE: Automatic Load Solver.xla
You should be able to load it through:
AddIns("Solver Add-In").Installed = True
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
Dear Dsi,
I tried your method by uncheck the solver and run the line which you recommended but it does not work. Do I need to specify the path to the library etc?
Thanks again.
EK
It seems to work OK, both  in the explicit and implicit versions:
    AddIns("solver add-in").Installed = True
or
    AddIns.Add("solver.xla").Installed = True
Note that the spelling and punctuation must be exact.  The explicit version does require you to know the actual file name, which, for Solver, is not too hard to figure out.
TTFN
Dear TTFN,
I tried the following code without checking the SOLVER.xla box manually and it won't work. Could you see anything wrong in the code?
The error message is:
"Compiled Error"
"Sub or Function Not Defined"
If I checked the solver.xla manually, it works fine.
Thanks again.
_____________________________
Sub Solver300()
' Solver used to solve stud with 300 spacing
SolverReset
SolverOptions Iterations:=10000, Precision:=0.01
SolverOk SetCell:="$G$16", MaxMinVal:=3, ValueOf:="0", ByChange:= _
"$B$15,$B$17,$B$18,$B$19,$B$20,$B$21,$B$22,$B$23"
SolverAdd CellRef:="$G$17", Relation:=2, FormulaText:="0"
SolverAdd CellRef:="$G$18", Relation:=2, FormulaText:="0"
SolverAdd CellRef:="$G$19", Relation:=2, FormulaText:="0"
SolverAdd CellRef:="$G$20", Relation:=2, FormulaText:="0"
SolverAdd CellRef:="$G$21", Relation:=2, FormulaText:="0"
SolverAdd CellRef:="$G$22", Relation:=2, FormulaText:="0"
SolverAdd CellRef:="$G$23", Relation:=2, FormulaText:="0"
    SolverSolve UserFinish = False
End Sub
___________________
sorry, I can't get the code to run either way, so there's something missing, like some sort of register command that registers the subcalls in the library?
TTFN
Sorry, you must be talking about the References Solver box.  That has to be checked, since that's the only way the VBA knows what the subcalls are.  I don't think there's any way around that.
TTFN
Another way is to check SOLVER library in Tools-preferences in VBA project. When it's checked the solver add-in will be activated automatically every time you open spreadsheet. (Assuming it's been installed during MS Office installation).
Thanks IRstuff and yakpol. I have tried yakpol's method and it works.... but only with office installed in the same directory and drive. I guess that is good enough considering most people install their office in "c:\program files" except those with dual boot.
Anyway, thanks for all your help and time.
EK
