Problem in saving NX5 Partfile
Hello Guys,
I have a problem while saving a part file.
 I have two components of LH,RH. I did complete modeling of LH and for RH  i have used wave geometry link option. After that some more features are added in both files. Today I did some modification in LH component,and it is automatically updated in RH component. But I am unable to save RH component,it is showing some error like Part file saving failed causing fail in over all save.
I tried save the file by suppressing and deleting  the modified feature. still it is showing same error.
Please give me a solution if any one knows.
Thanks.
RE: Problem in saving NX5 Partfile
Have you already done a Part Cleanup?
Try this first, or as John R. Baker suggested, if this doesn't work contact GTAC
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
