License Server
License Server
Hey all, so I have a license that allows up to 10 users to have access to it.
I currently have one computer that has the valid license and another computer on the same network pointing to that one, the same way itself does (28000@hostname).
What I'm trying to do now is do this on another computer that is not on the same network, but should be able to access it, since the network is not behind a firewall.
Can anyone assist on how to accomplish this?
RE: License Server
Use the full path name of the server.
Ben Loosli
RE: License Server
RE: License Server
28000@hostname.domain
Assuming you are running Windoze XP. Right click on My Computer on the Desktop of the computer that is your license server. Select Properties. Click on the Computer Name tab. Notice the Full computer name which should be hostname.domain. User that full computer name when prompted for the license server on the workstations on the other network. This assumes you have a trust established between the two network domains.
RE: License Server
RE: License Server
see if you can ping the license server from the new client either by hostname or the ip address.
Anthony Galante
Senior Support Engineer
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.1.5
RE: License Server
I have a similar problem:
My laptop is my licence server NX7.5 and my 2nd PC is able to access to the licence and start NX only if I stop the windows firewall open my laptop.
Any Idea
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: License Server
2. edit the license file so that on the ugslmd line you specify a port:
VENDOR ugslmd PORT=28001
3. restart the license service.
4. on the laptop, add two port exceptions in Windows firewall to allow port 28000 & 2800 through.
NX talks to the license server on 28000 but the secondary comms are on a dynamic port. The above sets the secondary port to a fixed port.
Anthony Galante
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.2.5
RE: License Server
Thanks four your answer
You say:
-------------------------------28001 !!!!
Could you explain the exact way to add port exceptions ?
and do we need to change the UGS_LICENSE_SERVER ?
TIA
Didier Psaltopoulos
RE: License Server
In fact, I succeed to find the good settings this WE with your explanation.
Thanks a lot, It works well.
For your information: GTAC was not able to help me !!!
Didier Psaltopoulos
