nx5 sketcher change line to reference line?
how to change line to reference line in sketcher??.
RE: nx5 sketcher change line to reference line?
Find the command: Convert to/From Reference
This should do the thing you want.
Pick the lines you want reference with left mouse button, then right click the selection and choose "convert to/from reference"
Works for curves and dimensions.
J
NX 6.0.5.3
Hi Jaydenn,
Thanks for this Tip, that is what this Forum is about share some Helpful tips and this was one I can appreciate!
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
Right mouse button is pretty powerful in NX, right clicking on many things will pop up a menu with filtered/associated tasks/commands e.g.
Right click on an edge and the top two options will be chamfer and edge blend, right click on a sketch in modelling and you get extrude and revolve etc etc.
Best regards
Simon NX4.0.4.2 MP10 - TCEng 9.1.3.6.c - (NX7.5 native)
www.jcb.com
Life shouldn't be measured by the number of breaths you take, but by the number of times when it's taken away...
