exApp As Excel.Application not defined
I have a SolidWorks2010 model and want to export Keypoints to an Excel table. I used the following code, which I found in the FAQs, as a macro. However, I get the following error message whenever I try to compile: "User defined type not defined" (Not literally, I translated it from German to English). "exApp As Excel.Application" is highlighted.
Any suggestions?
Any suggestions?
CODE
Sub main()
Dim swApp As SldWorks.SldWorks
Dim doc As SldWorks.ModelDoc2
Dim part As SldWorks.PartDoc
Dim sm As SldWorks.SelectionMgr
Dim feat As SldWorks.feature
Dim sketch As SldWorks.sketch
Dim v As Variant
Dim i As Long
Dim sseg As SldWorks.SketchSegment
Dim sline As SldWorks.SketchLine
Dim sp As SldWorks.SketchPoint
Dim ep As SldWorks.SketchPoint
Dim s As String
Dim exApp As Excel.Application
Dim sheet As Excel.Worksheet
Set exApp = New Excel.Application
If Not exApp Is Nothing Then
exApp.Visible = True
exApp.Workbooks.Add
Set sheet = exApp.ActiveSheet
If Not sheet Is Nothing Then
sheet.Cells(1, 2).Value = "X"
sheet.Cells(1, 3).Value = "Y"
sheet.Cells(1, 4).Value = "Z"
End If
End If
End If
Set swApp = GetObject(, "sldworks.application")
If Not swApp Is Nothing Then
Set doc = swApp.ActiveDoc
If Not doc Is Nothing Then
If doc.GetType = swDocPART Then
Set part = doc
Set sm = doc.SelectionManager
If Not part Is Nothing And Not sm Is Nothing Then
If sm.GetSelectedObjectType2(1) = swSelSKETCHES Then
Set feat = sm.GetSelectedObject4(1)
Set sketch = feat.GetSpecificFeature
If Not sketch Is Nothing Then
v = sketch.GetSketchPoints
For i = LBound(v) To UBound(v)
Set sp = v(i)
If Not sp Is Nothing And Not sheet Is Nothing And Not exApp Is Nothing Then
'sheet.Cells(2 + i, 1).Value = "Normal Vector " & i + 1
sheet.Cells(2 + i, 2).Value = Round(sp.x * 1000 / 25.4, DEC)
sheet.Cells(2 + i, 3).Value = Round(sp.y * 1000 / 25.4, DEC)
sheet.Cells(2 + i, 4).Value = Round(sp.z * 1000 / 25.4, DEC)
exApp.Columns.AutoFit
End If
Next i
End If
End If
End If
End If
End If
End If
End Sub
Dim v As Variant
Dim i As Long
Dim s As String
exApp.Workbooks.Add
End If
End If
End If
Set part = doc
Set sp = v(i)
End If
Next i
End If
End If
End If
End If
End If
End If
End Sub
RE: exApp As Excel.Application not defined
Help please, its urgent.
Thanks so much
What is DEC?
Have you tried stepping through the code? Does this expression evaluate to a value?
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
