OBTAIN SAME SURFACE COLOR IN DRAFTING
5
HI, I USE CATIA V5R18 AND WHEN I MAKE MY DRAWINGS FROM 3D PARTS I WANT THE SAME COLOR IN SOME VIEWS (FOR ISOMETRICS VIEWS) TO LOOK LIKE MORE PROFESSIONAL, BUT JUST THE LINES CHANGE COLOR AND NOT THE FACES OF THE PART.
IS IT POSSIBLE??
I PREVIOUSLY USED AUTODESK INVENTOR 2010 IN OTHER JOB AND I COULD DO THAT, I ASSUME CATIA CAN DO IT TOO, OR NOT??
RE: OBTAIN SAME SURFACE COLOR IN DRAFTING
You can use Fill Area, change hatch in pattern type with coloring.
Fernando
5
Just change the view to raster, shaded, ensure use 3d colours is checked and press Caps Lock once
Great Peter, I didn't know about that, star from me.
Fernando
THAT WAS VERY HELPFUL, THANK YOU PETERGUY!!!
The caps lock thing did not work then
It took me a while to understand the "caps lock" thingy, but now I just can't stop laughing... :DDDD
All in all, nice tip, thanks !
"..press caps lock once" ..........hilarious
one star for the caps lock...
Eric N.
