Rapid Drawdown Question
In a situation where you know you are going to have rapid drawdown, say an earth dam. What do you think is the best way to avoid a slope failure due to excess pore pressure within the embankment?
RE: Rapid Drawdown Question
f-d
¡papá gordo ain't no madre flaca!
Presuming this is the case, you might consider stabilizing berms on the water side. These can be built by carefully dumping on the water side in a controlled fashion. You could also, in conjunction, build a riprap face on the water side. - not easy but nothing with 60 year old would be easy . . . Run your stability computations with such geometric changes and see how your stability is increased.
Years ago, I was involved with the stabilizing of a causeway in northern Quebec on very soft (Su about 10 kPa) clay. Luckily, it was winter and the lake had several feet of ice. We were able to lay a stabilizing berm on the ice - it deflected and when melted, laid the stabilizing berm on the lake bed.
