Foldable Fabric / Mylar in SW Assembly
I am designing an umbrella for a client.  I have finished the actual rigid parts of it, and it looks really neat winky smile.
Now I need to put the "skin" on it.  The actual product might use paper, Mylar, or fabric.  Regardless of what material we decide to go with, I need to find a way to make an assembly that can have this "foldable" element to it.  Thickness is not important, I tried using surfaces, but that didn't work.
I am using SW-2006 right now.  If I need, I can use 2010, but I prefer to stay in 2006 if possible since that is what the client uses.
I would greatly appreciate any help anyone can offer.  If solidworks doesn't have this capability, what other program would be good for this?
Thanks.
RE: Foldable Fabric / Mylar in SW Assembly
I'd say that this is outside the realm of SW capabilities.  If you are stuck with using SW for this then I would take a look at just doing configurations of various opening angles.
Dan
www.eltronresearch.com
Dan's Blog
With some practice, I think it's possible something may work within sheetmetal.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
I doubt you will find an easy solution to the complex shape and doubt even more about finding a "dynamic" solution, i.e., one that changes as you open and close the mechanism.  I think your best bet is Dan's suggestion of making configurations of the device in several states.  Perhaps you can create a thin loft of a segment between and following the branches and pattern it.
- - -Updraft
I agree with Eltron and Updraft, static configurations is your best bet.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
After the configs are created, a video could be made by capturing each config in sequence. A long while ago, a macro was created to automate the process. I cannot remember it's name and cannot find it at the moment though.
Thinking in terms of an umbrella, could you define the edge by the tip as a 3D spline, create another one at the outer edge, then create several straight lines along the ribs as guide curves, and then do a surface or even a swept profile?
"then fold it til its all corners and go home?"
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
