low temp. psychrometric questions
I'm trying to figure out what happens to psychrometry when air gets really cold. I'm trying to get a handle on the TR required to bring air down to -65, but I have two problems. One, the ASHRAE charts only go down to -40. Two, it makes no sense to me to talk of relative humidity once air gets below 32F. The ASHRAE low temp charts follow this, as the chart I'm looking at does not have RH lines below 32F.
So, I guess my questions for you guys are
1) Is there a such thing as a psychro chart for -65F or equations of state that can be used at those low temps?
2) Is my thinking about air and RH below 32F on the mark? To me, it seems like you can chill air until 32F saturated, then the water begins precipitating out as a solid, then the air continues chilling as dry air to final temps. My gut tells me that to calculate loads, you'd start at the initial air state, then find the enthalpy difference between there and 32F saturated. Then, the absolute humidity would be used to calculate the amount of water in the air at 32F saturated, and the heat of fusion for that amount of water would be added to the load. Finally, the air would be treated as dry from 32F to -65F to calculate the third component. Does this seem reasonable?
RE: low temp. psychrometric questions
Still, RH below the freezing point of water is confusing me.
don't forget that "freezing" does not necessarily mean that ALL molecules are frozen. Thermo is a physics of amassed particles, so there is a statistic distribution of particle energies that allow some subset of the molecules to be at an elevated energy. Otherwise, triple-points wouldn't even be possible.
TTFN
Now that I have the nugget of information that lets my head accept dewpoints and humidities below 32F, do you know of any resources for low temperature psychrometrics below those -40F ASHRAE charts?
http://www.aktonassoc.com/ was the first link when googling "cryogenic psychrometric" -- it appears they have some calc software for very cold conditions.
Good on ya,
Goober Dave
Since last post, I checked out the Akton software, it goes down to -100°F. They're worth a call. It's not expensive.
Good on ya,
Weig
http://w
They claim humid air properties are computed via ASHRAE formualtion
Perry's Handbook has thermodynamic properties of moist air down to -160F. CRC Handbook has vapor pressure date down to -100C.
