feature manager push pin hot key
Is there a hot key to select the push pin to keep the feature manager open or can I assign one?  When inserting the same component multiple times in an assembly it would be nice to be able to hit a key rather then clicking it with the mouse.
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: feature manager push pin hot key
I don't understand your question. The F9 key will open/close the feature tree.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Ahhh, I see.
Yes, the push pin is worthless IMO.
Best to create your own hot key to do this.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Control drag from the assembly browser.
If you can't use a pattern when inserting a component multiple times, you can Ctrl-select and drag the part from within the graphics area.
Yes, I control drag a lot but it's nice to click and "drop" components in the assembly.  Control drag the mate ref. never seem to work right.
I'd like just a hot key and I know how to create one but I don't know what command the pin is under.  I scrolled the whole list and did not see it listed.  Just wondering if it is listed.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
