Laser Heat Treatment
I want to simulate a laser beam heating up a surface, but I'm just starting to learn how to use Abaqus. The Laser heats up 77 different points on the surface on after another. I want to use the subroutine DFLUX, but I don't know how to simulate the beam with a diameter of 60mm and a Gauss distribution. Thanks for your Help!
VictorMB
VictorMB
RE: Laser Heat Treatment
I will send you TIG welding simulation in abaqus 6.9 with surface gaussian distribution. It may help.
