How are ID Fans Loaded?
Hi to all,
I have a Milling circuit in my plant and have witnessed an interesting characteristic. First, here is the arrangement of our Milling circuit: 1. Ball Mill 2. Dynamic Seperater (then coarse return to Mill) 3. Cyclones (x4 of) 4a. Cyclone coarse product goes to Star/Rotary feeder and then to a Blower 4b. Clyclone fines go to a Catridge Filter then are fed into the Blower delivery line by Screw Conveyors 5. The Blower deliveres to Storage Silos. The whole system (save the Blower line) is air swept by the ID fan.
Last week we observed a decrease in the running amps of the ID fan. Then the old operators suggested we check the filter because it could be blocked, I agreed. But first I did a check, I measured the pressure differecial across the filter at low amps, then later when the amps went even much lower I measured again. I found that the relationship is: When the Pressure difference increases (blockage) the amps decrease. We then opened the filter, cleaned and replaced some catridges and now all is running perfectly.
Question: Why do amps drop when there's a blockage? When I put my hand behind my wife's hair dryer the amps go up, the dryer spins faster. Why is it defferent with the ID fan?
I look forward to your comments.
Thanks in advance.
Thanks in advance.
RE: How are ID Fans Loaded?
Johnny Pellin
FAQ237-1543: How does hp change with flow for a "centrifugal pump"
(2B)+(2B)' ?
