Hole Series with Sheet Metal
Hi All,
Getting an error that says "No Bodies for the Hole Series Feature to Cut" when trying to add a hole series between a weldment and a sheet metal part. There is already a hole wizard hole in the weldment part. The sheet metal part is created in context
Interestingly I added a dummy part in place of the sheet metal and the hole series worked. Then I unsuppressed the sheet metal part and it was added to the hole series.
Any thoughts?
60% of the time, it works every time.
RE: Hole Series with Sheet Metal
If you have SW 2010 SP4- I recently talked to tech support at our Solidworks reseller about various problems with the hole series and there are some SPR's(bugs) with the hole series functions in general. My parts were not sheet metal but there might be some carry over.
