Why can't I search past 2007?
Whenever I search the solidworks forums I only get results up to Oct 2007? Why is this?
I know this isn't the ideal location for this post but I couldn't find a general annoyance area.
60% of the time, it works every time.
RE: Why can't I search past 2007?
The search function built into the site is, ahem, under development.  Try Google instead.
Mike Halloran
Pembroke Pines, FL, USA
The Search function has not worked properly for a long time.
Till site management implements a solution, use the Google Custom Search field at the top of the page.
Great I thought I was losing my mind.
Are you talking about this forum?  If so, then the Limey nailed it.  However, if you're talking about the SW forums site then I think it had just started up in 2007.  I could be wrong.
Dan
www.eltronresearch.com
Dan's Blog
The SolidWorks forum over at www.solidworks.com has been around for years.  Way before 2007.  However, it has had several different forum software packages and some of the older content has been lost.
Not a big issue unless you are using an old version of SolidWorks.
Anna Wood
Core i7 EE965, FirePro V8700, 12 Gb RAM, OCZ Vertex 120 Gb SSD, Dell 3008WFP 30" Monitor
SW2011 PR1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
