Lettering Angle for Annotations in NX5
For some reason, whenever I go to add an annotation, ID symbol, etc. the lettering angle defaults to 90.99 degrees.  How do I get it to default back to 0.
Thanks in advance,
lurks
RE: Lettering Angle for Annotations in NX5
Check your Customer Defaults to see if someone has changed it there (do a search on 'Letterint Angle').
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Are you using a template (or seed part)? If so, check the settings in that file as well.
I found the problem.  For some reason the default was changed in the preferences for annotations.  I changed this and everything is good.  Thanks for your help.
lurks
