What tests are required for PQR?
In qualifying a welder, QW-302.1 refers to QW-452. In 452.1 it shows hat Visual examination can be used on the thicknesses shown. My questions are "do you need to perform tensile strength tests for a PQR?" and "Is a visual and bend test enough?"
RE: What tests are required for PQR?
If you are qualifying a welder, tensile testing is not required.
If you are qualifying a welding procedure, you should be looking at Table 451.X to determine the testing requirements.
Best regards - Al
Witness the making of the PQR coupon
VT - visual inspx of coupon weld
2ea. Tensile 'pulls'
4ea. Bends
It's not onerous when you consider that the PQR is now valid for the life of your company. It should be considered as a Capital Expense, not a job cost.
Witness coupon being welded
Visual Inspx of coupon
EITHER: 1) 2ea. Bends [not the 4 required for PQR's]
or 2) Volumetric Examination; RT like always, or Ultrasound - UT - if thickness is 1/2" or more.
