What is "shake down", "self limiting stress" and "rache
I am new to piping engineering and need some help from the experts in understanding some terminology/concepts(see below).
1)what is shake down?
2)Explain self limiting stresses and why primary loads are not self limiting?
3)what is ratcheting? Is it the same as cyclic fatigue?
RE: What is "shake down", "self limiting stress" and "rache
What parts of these terminologies do you not understand?
To my understanding, shakedown is the process when the pipe material plastically deforms in a hot stage and then goes back to elastic phase in a cold state. After the cold to hot and back to cold operating conditions (aka 1 cycle), the material self springs (aka has residual stress). Then after the next cycle, from cold to hot, the piping stresses must overcome the residual stresses before it can actually cause stresses on the pipe.
Self limiting stresses are stresses caused by thermal strain. For a controlled cased, a heated pipe will expand a certain length due to a Temp limit (aka design temp). It will not grow longer than it did in its previous cycle. If the material were to be constrain, it would yield thus relieve the stresses. Therefore, the material will yield but eventually "shake down" during the cooling stage. But for certain, the strains leading to stresses will not increase throughout the cycles because the piping system will not go above its design temp.
Sustain loads are continuous forces (weight, pressure, external loads) acting on the system. If something yields, its cross sectional area will decrease and the loads will stay constant;this will cause progressive stresses that will eventually take the material to failure.
material that plastically deforms every peak in the cycle. This reduces cross sectional area thus increases stresses. Because the same loads are applied after each load, stresses are increased and exceeded in every cycle.
Just a few notes:
2) Self limiting stresses are not only caused by thermal strain.
You can figure the difference with respect to primary stresses this way: primary stresses must follow the laws of equilibrium, an increase in the load necessarily results in a stress increase; secondary stresses are caused by the requirement of compatibility in strains, once the compatibility is attained by plastic deformation, no stress increase will come from a load increase (if the stress-strain curve after yield is flat).
3)Ratcheting is also called low cycle fatigue. Failure is not necessarily due to reduction in area, but more generally to the achievement of a rupture limit in strain.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
