Compression only Springs
I am trying to translate a long hand matrix analysis for a small portal frame , 2 columns , one beam across, into an excel/VBA. how could I model/include compression only spring for one of the column bases. that is if there is an upward load the spring wont be effective.
RE: Compression only Springs
You could set the springs as new members with a non-linear material with a normal young modulus in compression and a very small one for tension to avoid convergence problems.
