NX vs. Pro-E
NX vs. Pro-E
Hi NX'ers,
If a company is considering purchasing NX or Pro-E & knowing there's a significant coast difference, what would be your suggestions to highlight the benefits & disadvantages of using NX & Pro-E?
Jason M.
Unigraphics NX Designer
RE: NX vs. Pro-E
RE: NX vs. Pro-E
Working with turbine blades with freeform surfaces
Jason M.
RE: NX vs. Pro-E
John - You seem to be the NX guru of this forum.
I work for a company that has some facilities that use NX only, while others use Pro-E only. Additionally, some use both CAD applications.
At the moment, the facility I'm at has only NX,but is likely to also get a seat of two of Pro-E.
The big "management" question is that Pro-E is considerably cheaper than NX from a cost point-of-view.
I'm told that floating Pro-E license costs approximately $5K, where as NX floating license, depending on module, ranges $15K - $25K.
At a glance & I'm not highly familiar with Pro-E, but the two CAD applications seem very similar in terms of its feature capabilities or functionalities.
If conducting a CAD Analysis, how would you highlight the similarities/differences or pros & cons of each CAD application?
Jason M.
RE: NX vs. Pro-E
One thing to consider is your cad designs will make it to someone's cam program. For that reason, several of the turbine shops are now looking at NX's integrated turbine machining package. If their model is native NX, you'll get better pricing on the NRE.
Bill
RE: NX vs. Pro-E
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RE: NX vs. Pro-E
RE: NX vs. Pro-E
As you probably know, CAD jobs will vary by complexity. The company I work for specializes with making turbine blades.
These in itself, have a bit of complexity. If you had a choice to use Pro-E or NX to make a turbine blade - Let's say, semi-complex or any semi-complex product with freeform or wavey surfaces, which CAD system would you use & why?
Jason M.
RE: NX vs. Pro-E
Never did turbine machining, but know people and companies that do. Most of them are using NX. Also, if they do their own machining, NX has the modules to do blade machining that will make life easier for your NC programmers. When you look at Pratt & Whitney and GE, they both use NX for their engines.
Ben Loosli
RE: NX vs. Pro-E
As does Rolls Royce and Honeywell, to name a couple more turbine engine builders.
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: NX vs. Pro-E
Thanks for the feedback. Having worked in the turbine industry for number of years, as well as working (contracting) for P & W & GE, I know they primarily use NX. However, at least with GE, are starting to use SolidWorks & I hear some may be using Pro-E as well & perhaps, Catia for a project or two.
Now, I'm trying to figure out what the Pro-E base package is & what the upgrade modules are to compare. Does anyone have a good reference to direct me to?
Jason M.
RE: NX vs. Pro-E
http://www.ptc.com/products/proengineer/
Scroll down and the information is on the right.
My guess is you would need at least the Advanced XE package to compare to the Advanced Design bundle of NX.
I haven't seen an NX data sheet to give a better comparison.
Ben Loosli
RE: NX vs. Pro-E
Thanks for the Pro-E info. I wasn't sure what the Pro-E modules are called. Hopefully, this will give a better comparison.
Jason M.
RE: NX vs. Pro-E
Also note that other companies use Pro/E for bladed design and manufacture, particularly in the power industry.
RE: NX vs. Pro-E
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: NX vs. Pro-E
The last company I was with was ready to pull the trigger and purchase a seat of Catia in addition to the existing NX seats it had, only waiting for "that next big contract", but ProE was never considered.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
RE: NX vs. Pro-E
Ben Loosli
RE: NX vs. Pro-E
What I've seen thus far, plus doing some other research, both Pro E & NX has its advantages & disadvantages and comparable in almost everything in terms of functionalities or capabilities. Thus far, at least in my research, there's not a single thing that highly stands out as being explicitly better or worse.
However, I'm still trying to figure out why there significant cost difference between ProE & NX. According to one source, I'm told that ProE cost approx. $5K & NX is upwards to $25K.
Jason M.
RE: NX vs. Pro-E
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: NX vs. Pro-E
Try asking PTC sales for the price of the CREO/Pro Enterprise SE package and add 5-axis machining. You will see that it isn't $5K.
The NX package that I have seen in the $25K range is the advanced machining bundle.
Like John said, get a full module listing with each bundle and then do your comparison. My PTC bundle has about 20 modules in it, but the data sheets only highlight about 7.
Ben Loosli
