wet gas compression
wet gas compression
Looking for best options to compress approximately 24,000 MSCFD wet gas, after separator, on offshore facility from about 100 psig to 150-170 psig.
RE: wet gas compression
David
David
David
I'd guess you need a small footprint and smooth operation (little vibration or coupling forces).
If you have electrial for the 70 or 700 kw, I'd look at a sundyne centrifugal compressor. Other than that, a screw compressor fits the bill as either an electric or gas engine drive.
h
Best regards
Morten
