Update displaying view
when I switch from a drawing to an assembly, not very big, the refreshing views, take a lot of time..1 min.
If the assembly is big, 2 min.
This lose time x n°switch...in the work day, it's lot time lose.
There are some setting to avoid this losing time, maybe refresh only the work view for example.
other users have the same problem ?
Thank you...
Using NX7.0 and TC8.1
RE: Update displaying view
I suggest that you move to NX 7.5 as we have made some significant changes with respect to the use of Lightweight Representations which has an impact on display performance, particularly when switching between the Drafting and the Modeling modules.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
Thanks John,
but we have switched to NX7 some months ago, and we haven't planned to re-switch again.
Thank you...
there are some settings in view style, for sections for ex., the hidden line hatching, can cause those problems.
When you say NX 7 do you mean NX 7.0?  If so, we highly recommend that you consider moving to NX 7.5 since NX 7.0 has already been moved to critical bug fix status.  There will be NO more general MR's (Maintenance Releases) for NX 7.0, ONLY MP's (Maintenance Patches).
John R. Baker, P.E.
Industry Sector
Cypress, CA
I John...I know about 'There will be NO more general MR's'.
I updated my signature.
Thank you...
Using NX 7.0.1.7 MP1 and TC8.1
