Stop heat transfer with rubber!
Hi all, I need to coat aluminium profiles with some kind of rubber in order to minimise the heat transfer through them, but I dont know any product that can do a thermal barrier. Any recommendation about product and process?
Many thanks
Many thanks
RE: Stop heat transfer with rubber!
Adriaan.
I am an Engineer/part time student (Mechatronics) from South Africa.
Advice from lecturer: "Be warned - when you go into industry your boss will give you a thousand things to do and he wants them done yesterday!" So far he is right...
What temperatures are you considering?
Most elastomeric materials fail at lees than 200°C
h
www.tynevalleyplastics.co.uk
http://www.nationwidecoatings.com/prod10.htm
There are other approaches besides a solid material. Thin (>13 mm, <20 mm) air gaps work tolerably well; fiberglass insulation is mostly air, when you get right down to it. It's basically an air gap that is prevented from convecting by the fiberglass. Air has an R-value of about 5.5 per inch of thickness, assuming no convection.
see http://e
TTFN
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
