Replacing batteries in a cordless drill
Hi!
I have a cordless drill battery in which I want to replace the inside batteries. (There likely isn't a standard replacement battery available since it's not a "large brand" drill.)
I opened up the battery, and found 13 smaller batteries inside. Smaller than a D-size battery, they measure about 21.5mm (diameter) x 40.5mm (height), not measuring the tip. The outside paper (wrap around the battery) had a marking on it "7D" and also "BC" was noted directly on the metal of the battery (under the paper).
Looking on wikipedia and the net I could not find any similar battery size.
My question: does anyone have an idea what this battery is called and/or where I could find some?
Joining them back together is something I should be able to do using a soldering iron.
God Bless & Thanks,
Roel
God Bless & Thanks,
Roel
RE: Replacing batteries in a cordless drill
http://www.gpdirectusa.com/PDF/toyhobbycat.pdf
But, they seem to be pretty pricey:
http:
TTFN
