Storage Tank level controls
I would like to boost the incoming water pressure to some equipment.
I want to connect the city feed to a 200 gallon storage tank.
I need a valve that will open and close when the high and low level controls signal the tank is either low or full.
Any suggestions on what components I can use? Thanks
RE: Storage Tank level controls
You can also use a more complicated method that involves a separate level sensor/transmitter, a separate level controller, and a separate modulating valve. This system is much more expensive, but capable of better control. With this system, you set the level that is desired on the controller and the controller will autmatically maintain the water level. There are many options as to the types of instruments that are available. Refer to the schematics.
Without knowing anything else about your system, that is all that can be said.
Some time ago you were asking about pressure controllers and back pressure controllers. I attached an article regarding these instruments.
You may need a stilling well around the float depending upon whether there is any wave motion on the surfce of the reservoir.
These devices are much simpler than having a control loop.
"I am sure it can be done. I've seen it on the internet." BigInch's favorite client.
http://www.youtube.com/watch?v=hpiIWMWWVco
"Being GREEN isn't easy." Kermit
http://virtualpipeline.spaces.live.com
Good point!
Thanks guys.
