Mean Line Circumference?
I've found that shell plate, if strapped after rolled, grows on the outside of the plate more than it compresses on the inside of the plate. This is understandable since steel has more strength under compression than tension- also, I don't see any real problem as long as all the shell courses are calculated using the same mean line, all courses should be the appropriate length with relation to the next course. What if you're dealing with a 4" thick wall vessel? -miscalculating the mean line may result in a large variation of capacity. Should the mean line calculation used in determining plate length actually be closer to the inside of the shell rather than the center of the shell plate? Is there a generally accepted standard?
RE: Mean Line Circumference?
