Move Sketches
Move Sketches
You would think this would be self explanatory, but I am having a heck of a time moving sketch entities.
I have a base sketch that I have remove all the dimensions making it defined so it can be moved. When I select all the sketch entities and click Move/Sketch Entities it has all the sketch lines pre-defined. I want to use the From\To option. I made a special construction line to move from one point to another. I click the first point and I get the yellow globe... I cannot go any further, every point, edge line, out in space that I select I just seem to re-select the start point and the sketch never moves.
Anyone else seeing this?
The help reads:
The image that is provided just shows the user placing the entities where they want it in space from one point to another... not working here!
VAR is not any help today when calling in, because they never pick up the phone.
The help reads:
Quote:
From/To. Adds a Base point to set a Start point and a destination.
Scott Baugh, CSWP ![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
Berry Plastics
Cad Admin\Design Engineer
www.scottjbaugh.com
FAQ731-376: Eng-Tips.com Forum PoliciesQuote:
"If it's not broke, Don't fix it!"
RE: Move Sketches
Sure would be nice if the Command gave a reason why a user could not move the sketch. Wasted about 20 minutes trying to figure out why it wouldn't move.
I have found many commands that just don't give enough or any information as to why they will not complete the task.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
www.scottjbaugh.com
RE: Move Sketches
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
RE: Move Sketches
Move sketch entities still didn't work, I had to copy the sketch and remove the original sketch... which means everything in my tree is going to fail, surfacing... everything associated to the Base sketch profile will fail now.
Thanks Solidworks for making Move\Sketches so simple! This will now put me hours behind schedule and the file is due tomorrow.
www.scottjbaugh.com
RE: Move Sketches
Moving sketches in SW is very easy.
1) Window select all entities you want to move;
2) Ctrl select a point (from);
3) Release ctrl key;
4) Drag N drop to target point;
Good Luck!
Alex
RE: Move Sketches
I tried "Move Sketch Entities" command. I duplicated your finding.
If you try the method I use, you will be able to move any of sketch entities around precisely.
Best regards,
Alex
RE: Move Sketches
RE: Move Sketches
RE: Move Sketches
From the help file 2010:
Move or Copy Sketch Entities
To move or copy entities:
In sketch mode:
Click Move Entities (Sketch toolbar) or Tools, Sketch Tools, Move.
- or -
Click Copy Entities (Sketch toolbar) or Tools, Sketch Tools, Copy.
Dimensions are moved or copied to the new location with the entities. Relations are moved or copied only if you select Keep relations.
In the PropertyManager, under Entities to Move or Entities to Copy:
Select sketch entities for Sketch item or annotations.
Select Keep relations to maintain relations between sketch entities. When cleared, relations are broken only between selected entities and those that are not selected; relations among the selected entities are maintained.
Under Parameters:
Sketch Type
Instructions for modifying parameters
2D Sketch
3D Sketch On Plane
Do one of the following:
Select From/To, click Start point to set a Base point , and then drag to position the sketch entities.
Select X/Y and set values for Delta X and Delta Y to position the sketch entities.
Click Repeat to modify the position of the sketch entities again by the same distance.
That really needs to be updated... holding that one button did not occur to me and would have saved me hours worth of work.
www.scottjbaugh.com
RE: Move Sketches
Rob Stupplebeen
RE: Move Sketches
Stefan Hamminga
EngIT Solutions
CSWP/Mechanical designer
Searching Eng-Tips forums
