Icon / Toolbar to Switch Units
I've tried but cannot figure out. Is there a way to create a macro or something to make an icon that I can toggle back and forth between inches and millimeters?
Appreciate the help!
RE: Icon / Toolbar to Switch Units
Not sure if you really need a macro for this.
Just set the properties to the units you use most often, and then add a " (or mm) after the number when you need to use a value in the other unit.
Hi
This is a CATScript which I posted in a Spanish forum:
Language="VBSCRIPT"
Sub CATMain()
Dim oSettingControllers As SettingControllers
Set oSettingControllers = CATIA.SettingControllers
Dim oUnitsSheetSettingAtt As SettingController
Set oUnitsSheetSettingAtt = oSettingControllers.Item("CATLieUnitsSheetSettingCtrl")
Dim oMagnitude as String
oMagnitude = "LENGTH"
Dim oUnit as String
oUnit = ""
Dim oGetDecimal as Double
Dim oGetExpo as Double
oUnitsSheetSettingAtt.GetMagnitudeValues oMagnitude, oUnit, oGetDecimal, oGetExpo
If (oUnit = "Inch") Then
Dim oUnitInch as String
oUnitInch = "Millimeter"
oUnitsSheetSettingAtt.SetMagnitudeValues oMagnitude, oUnitInch, 6.000000, 3.000000
oUnitsSheetSettingAtt.SaveRepositoryForUnits()
oUnitsSheetSettingAtt.CommitForUnits()
oUnitsSheetSettingAtt.Commit()
MsgBox "The Current Unit is now: " & oUnitInch
End If
If (oUnit = "Millimeter") Then
Dim oUnitMM as String
oUnitMM = "Inch"
oUnitsSheetSettingAtt.SetMagnitudeValues oMagnitude, oUnitMM, 6.000000, 3.000000
MsgBox "The Current Unit is now: " & oUnitMM
End If
CATIA.StartCommand "Options"
call CATIA.SystemService.ExecuteBackGroundProcessus("WScript.exe c:\SendEnter.vbs")
End Sub
Paste what is bellow in a file named SendEnter.vbs (vbs is the extension of the file)
Set WshShell = WScript.CreateObject("WScript.Shell")
WScript.sleep 200
WshShell.SendKeys "{ENTER}"
Fernando
Thanks Ferdo! Just what i needed. It's more of less for for when measuring and checking items rather then inputing sizes when designing. If I could set dual unit's when measuring - that would be useful also.
I ran the script and like the way it works, however if your are not on the Tools/Options/Paramaters and Measures/Units page, it does not allow you to click ok and the switch doesnt take affect until I go to this page.  Is this a glitch in Catia.  Is there a way around this so I dont have to this or say ok everytime I switch units....just wondering
That's why you need the second vbs file, directly on c:\ , its sending Enter from keyboard.
Fernando
I did use the second vbs file, but if my tools option page is not on the units page, it says ok for me but still measures in the original unit, then when i check the units in tools options, it has switched.  if i'm on the units page and run the macro, it waits for me to say ok then it works
